Could not issue an SSL/TLS certificate for martin-preussner.de Details Could not issue a Let's Encrypt SSL/TLS certificate for martin-preussner.de. Authorization for the domain failed
Error -Message:
Details
Could not issue a Let’s Encrypt SSL/TLS certificate for martin-preussner.de . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/4015808383.
Details:
Type: urn:ietf:params:acme:error:unauthorized
Status: 403
Detail: Incorrect TXT record “yql9ep7KNb0rnqtuAwGme6BZ5oiSf74ZpAjWOdjPm_4” found at _acme-challenge.martin-preussner.de
Dear @swemp26121,
Could you please tell us what isn’t clear about the error message? For me, it tells you perfectly what is going wrong. But perhaps for you, it isn’t clear. Could you tell us why?
Also, if you’d like more help with your issue, you’ll need to answer the questions provided, not just copy/paste the error message.
Hello!
Because my vserver did not work yesterday. So I reinstalled the image of my hoster 4 times! But only today the vserver worked as it should do. Now the Let’s Encrypt works! Thank you for a good job!
Best wishes
Martn Preussner
