ERROR: Could not issue an SSL/TLS certificate
My domain is: kindertagespflege-kirchhellen.de, ktp-kirchhellen.de(alias), bin-im-garten.online(alias)
I ran this command: / Install Free Certificate By LE (Plesk UI)
It produced this output: Could not issue an SSL/TLS certificate for kindertagespflege-kirchhellen.de
Details
Could not issue a Let's Encrypt SSL/TLS certificate for kindertagespflege-kirchhellen.de. Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/353967154692.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: 85.215.128.138: Fetching Home - Kindertagespflege "Bin im Garten" Kirchhellen Connection refused
My web server is (include version): Apache/2.4.52
The operating system my web server runs on is (include version): Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: IONOS
Plesk Obsidian v18.0.60_build1800240421.18
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): /
EDIT:
LE Debug is not able to find any issues: https://letsdebug.net/kindertagespflege-kirchhellen.de/1971603
The non-reachable files are reachable from my side via Chrome.
Hello @KimiSchulte, welcome to the Let's Encrypt community. :slightly_smiling_face:
This:
and this:
are referencing 2 different Domain Names and the 2 names are not resolving to the same IP Address.
nslookup kindertagespflege-kirchhellen.de ns1.bonum-hosting.de.
$ nslookup kindertagespflege-kirchhellen.de ns1.bonum-hosting.de.
Server:         ns1.bonum-hosting.de.
Address:        82.220.34.231#53
Address: 85.215.233.136
From around the world Permanent link to this check report is showing "OK".
nslookup ktp-kirchhellen.de ns1.bonum-hosting.de.
$ nslookup ktp-kirchhellen.de ns1.bonum-hosting.de.
Address: 85.215.128.138
from around the world Permanent link to this check report is showing "Connection refused".
Thank you! Did not even check that...
