Error: Could not issue a Let's Encrypt SSL/TLS certificate for foo.es. Authorization for the domain failed
My domain is: I can’t provided
I ran this command: Plesk let’s encrypt install
Error: Could not issue a Let’s Encrypt SSL/TLS certificate for foo.es. Authorization for the domain failed.
Additional error details: Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/6oS_4St36yjkbRdBhdW_TJbQhUfq7sMQ0hC2yZvFib4. Details: Type: urn:acme:error:connection
Status: 400
Detail: Fetching http://foo.es/.well-known/acme-challenge/lbtHy3ads9eVXiLOP6NBFUkMyUOJj-PqZitW9Hv_Qwk: Timeout
My web server is (include version): Plesk 12.5(Nginx & apache installed)
The operating system my web server runs on is (include version): Ubuntu 14.04
My hosting provider, if applicable, is: I have the domain with dinahosting and the server with 1and1
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk 17.5
I tried to include the TXT DNS _acme-challenge.www.foo.es
I checked the DNS, without significative fault.
http://es.tinypic.com/r/k9tbg1/9
I can acces to http://foo.es/.well-known/acme-challenge/lbtHy3ads9eVXiLOP6NBFUkMyUOJj-PqZitW9Hv_Qwk through my browser
I don’t know what more to do.
log this with plesk if you are using their system as they may be able to help
without a domain people on this forum have decided that we will not spend time troubleshooting as the obvious things usually don't occur to the person communicating and asking for help (hence the requirement for domain names so people can verify DNS setups etc)
an example of such a case How can I verify my domain?
You are free to investigate you own root causes by browsing the forums
Andrei
