Could not issue a Let's Encrypt SSL/TLS certificate for domain
Could not issue an SSL/TLS certificate for api.felizsoftware.com
Details
Could not issue a Let's Encrypt SSL/TLS certificate for api.felizsoftware.com.
The authorization token is not available at http://api.felizsoftware.com/.well-known/acme-challenge/J8n2v3-xK5xmO0a8PNRfOX6t-vhK-LbDB5eC7cX5hpc.
To resolve the issue, make sure that the token file can be downloaded via the above URL.
See the related Knowledge Base article for details.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz/2362505167/511451638437
Details:
Type: urn:ietf:params:acme:error:unauthorized
Status: 403
Detail: 71.163.150.83: Invalid response from http://api.felizsoftware.com/.well-known/acme-challenge/J8n2v3-xK5xmO0a8PNRfOX6t-vhK-LbDB5eC7cX5hpc: 500
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it (and make our life a lot harder). In any case, all the answers to this questionnaire are required:
@felizsoftware We won't be able to give specific advice without the info from the form Osiris re-posted.
But, your IIS Server is not replying to any HTTP requests. Not even for your "home" page. You should fix whatever is causing the "500 Internal Server Error" and then try getting a cert.
curl -i http://api.felizsoftware.com
HTTP/1.1 500 Internal Server Error
Content-Type: text/html
Server: Microsoft-IIS/10.0
X-Powered-By: ASP.NET
Date: Sat, 26 Apr 2025 14:46:57 GMT
Content-Length: 1208
Thank you for letting me know about the IIS issues. I will work on fixing them and come back to get assistance on getting a cert.
