Could not issue a Let's Encrypt SSL/TLS certificate for boschcentre.co.uk. Authorization for the domain failed
My domain is: broadstairsmotcentre.co.uk, which is mapped to http://broadstairsmotcentre.boschauto.co.uk/
I ran this command: Plesk - Add Domain to mapped Domain - No issue with other domains
Error: Could not issue a Let’s Encrypt SSL/TLS certificate for boschcentre.co.uk. Authorization for the domain failed.
Details
Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/Z1cdb1nzUGlv1Nr8imtM6V2hvnjY8Exfi2vYC8mKkiQ.
Details:
Type: urn:acme:error:unauthorized
Status: 403
Detail: Invalid response from http://broadstairsmotcentre.co.uk/.well-known/acme-challenge/gnJ_8OdjFq5kh4XJNjPGda9NsQ3f7j3bQtiBDtXt_lQ: "
<html class" My web server is (include version): The operating system my web server runs on is (include version): My hosting provider, if applicable, is: Webfusion I can login to a root shell on my machine (yes or no, or I don't know): I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk
I see that you are using Plesk control panel.
But can you also login to a root shell on my machine?
403 errors are generally authentication related.
Also:
Those names aren't pointing to the same IP (that may be part of the problem...)
Address: 94.136.34.83
Address: 79.170.40.46
You star, thank you. I’ll investigate the DNS settings
