My domain is: http://jksbordplade.dk/
I ran this command: Tried Let’s encrypt
It produced this output: Error: Could not issue a Let’s Encrypt SSL/TLS certificate for jksbordplade.dk . Authorization for the domain failed.
Additional error details:
Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/1XMmk1Y1JJ5KAoRps8gLTaifKyo3ezJ5IgRjpgKmZRs .
Details:
Type: urn:acme:error:unauthorized
Status: 403
Detail: Invalid response from http://jk-staal.dk/.well-known/acme-challenge/oQz7t8XtCpQ8PJOXIr0Dx91I5qS-15fMJTf0poCyNuY: "
404 Not Found
<body style="color: #444; margin:0;font:"
How do i fix this error, so i can succesfully issue a Let’s Encrypt SSL/TLS certificate for my domain jksbordplade.dk ?
Real new at this, without much exp. so please be clear in your instructions. Thanks
rg305
October 13, 2017, 8:40am
#2
Optimeo-Emil:
404 Not Found
Means it could not serve the requested file: http://jk-staal.dk/.well-known/acme-challenge/oQz7t8XtCpQ8PJOXIr0Dx91I5qS-15fMJTf0poCyNuY
Optimeo-Emil:
That depends on the exact cause of the 404 error.
Which could be any number of things.
In order to figure that out, maybe you could answer a few questions:
Exactly what was the Let's Encrypt command line you tried?
How are "jksbordplade.dk" and "jk-staal.dk" related? Did you try to get certs for more than one domain?
Which O/S are you using? (and version)
Which LE client are you using? (and version)
system
closed
November 12, 2017, 8:40am
#3
