elnoraspantry.com
sudo certbot --apache
File “/usr/bin/certbot”, line 6, in
from pkg_resources import load_entry_point
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 3250, in
@_call_aside
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 3234, in _call_aside
f(*args, **kwargs)
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 3263, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 583, in _build_master
ws.require(requires)
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 900, in require
needed = self.resolve(parse_requirements(requirements))
File “/usr/local/lib/python3.7/site-packages/pkg_resources/init.py”, line 786, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The ‘six>=1.9’ distribution was not found and is required by mock
httpd -v
Server version: Apache/2.4.41 (Fedora)
Server built: Oct 3 2019 08:50:37
Linux steve-2.wowway.com 5.2.18-200.fc30.x86_64 #1 SMP Tue Oct 1 13:14:07 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
no
or certbot-auto --version
if you’re using Certbot):
from dnf output: version 0.38.0 release 1.fc30
What do I need to upgrade to fix this error?
