My domain is:www.kidfrankensteinthemusical.com
sudo certbot --apache
File "/usr/local/bin/certbot", line 6, in
from pkg_resources import load_entry_point
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 3251, in @_call_aside
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 3235, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 3264, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 583, in _build_master
ws.require(requires)
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 900, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/dist-packages/pkg_resources/init.py", line 786, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'configobj' distribution was not found and is required by certbot
Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.3 LTS
Linux server 5.4.0-90-generic #101-Ubuntu SMP Fri Oct 15 20:00:55 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
My hosting provider, if applicable, is: OLM.NET
YES
NO
certbot 0.24.0.dev0
How did you install that version of certbot? Because the .dev0 versions aren't packaged in an official way as far as I know. Please use a regular method of installing certbot, preferably a more recent version and by using the official guide at https://certbot.eff.org/
That ancient version would not have been installed using snap as the official guide says. It seems you have multiple instances of certbot on your system.
What does whois certbot say? And what does ls -l /snap/bin/certbot say?
Also, the question on how to remove the old version really depends on how you installed it in the first place.
sudo /usr/bin/certbot --apache
Error while running apache2ctl configtest.
Action 'configtest' failed.
apache2: Syntax error on line 219 of /etc/apache2/apache2.conf: Syntax error on line 8 of /etc/apache2/sites-enabled/flightschoolthemusical.com-le-ssl.conf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError("Error while running apache2ctl configtest.\nAction 'configtest' failed.\nThe Apache error log may have more information.\n\napache2: Syntax error on line 219 of /etc/apache2/apache2.conf: Syntax error on line 8 of /etc/apache2/sites-enabled/flightschoolthemusical.com-le-ssl.conf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory\n")
I think certbot is running now but:
Requesting a certificate for xxxx.com
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
