ModuleNotFoundError: No module named 'certbot'
website-prod-search-engine-northeurope.cloudapp.azure.com
certbot --version
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 480, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2693, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2324, in load
return self.resolve()
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2330, in resolve
module = import(self.module_name, fromlist=['name'], level=0)
nginx 1.14.0
ubuntu 18
Hi and welcome!
Why would you use an FQDN from "azure.com" ?
Your certbot probably failed while trying to update itself.
I would:
Perhaps just follow the instructions here? :wink:
Admittedly, yours are more concise, rg305.
It's not worth fixing.
You need to be at least at 1.6.0.
Fixing? I don't understand.
In case anyone thinks...
I can fix that!
Version 0.31.0 ain't worth fixing.
I can fix it... :bomb:
