No module named certbot
My domain is: floristpony.eu.org
I ran this command: /opt/certbot/bin/certbot certificates
  File "/opt/certbot/bin/certbot", line 5, in <module>
    from certbot.main import main
ModuleNotFoundError: No module named 'certbot'
My web server is (include version): nginx 1.22.1
The operating system my web server runs on is (include version): Debian 12 (bookworm)
My hosting provider, if applicable, is: Google Cloud (using free credits, at the moment)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): probably latest, I forgot to check
So yeah, maybe because of python upgrade, I no longer able to execute certbot commands. And yes it's on virtual environment (after dealing with apt broken packages error while turns out I need to manually install the latest version of python3-venv package)
How do I fix this issue? Thank you.
If you're using our pip instructions, you will need to destroy and recreate the virtual environment from scratch after upgrading to a new Debian major version.
Your data isn't stored in /opt/certbot, so it's safe to delete it and follow the instructions from the beginning.
Yup, it worked. Thank you very much :blush:
