Assistance with Installing CertBot: python-certbot-nginx
I ran this command: apt-get install certbot python-certbot-nginx -t stretch-backports
It produced this output: E: Unable to locate package python-certbot-nginx
My web server is (include version): NGINX v1.10.3
The operating system my web server runs on is (include version): Debian 9.9
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): N/A, can’t get it installed because package is not found.
Hello All,
I am trying to install CertBot on my Debian 9 instance with NGINX. I have added the proper backports repository as instructed by the documentation, but the problem is that the following command returns an error with the package: apt-get install certbot python-certbot-nginx -t stretch-backports
It cannot find ptython-certbot-nginx.
Any recommendations?
Thanks!
Z
That package is just a legacy package for the transition from Python 2 to Python 3.
You might want to try python3-certbot-nginx
How did you add the stretch-backports repository to your list of repos? Did you run ‘apt-get update’ after to bring in the repo metadata?
Hi Osiris,
I am receiving the same error when trying to run that command as well.
Thanks!
Z
Hi mproto,
I added the stretch-backports utilizing the following documentation:
Listed on the CertBot website installation instructions: https://backports.debian.org/Instructions/
That link did not work for me, so I utilized the following Debian Wiki to install the backports: https://wiki.debian.org/Backports
Specifically, the ‘Using the Command Line’ section of this documentation. I did run apt-get update and it is hitting the repo successfully.
Any other thoughts?
Thanks!
Z
Hmm I just installed Debian 9.9 in a VM and after adding static-backports I could find both packages immediately.
What results do you get with ‘apt-cache search certbot’ ?
Hi mrproto,
Thank you for the update… this is very interesting. Running that command I can see both of the packages sitting there. I wonder why when I try to install them it declares it couldn’t find those packages.
Maybe it’s an issue with how I added the repo. I’m going to have to do some digging on this one.
Thanks!
Z
Sure! When you find your answer kindly report back here, in case someone runs into a similar problem as yours in the future.
Hi mproto,
I certainly will!
Hope to update soon!
Thanks for your assistance!
Z
Hi All,
I was able to resolve this issue, I don't necessarily think it was an issue with how I installed the backports, but rather the format of the command given on the website for installing python-certbot-nginx.
Here is the command:
$ sudo apt-get install certbot python-certbot-nginx -t stretch-backports
Listed on the certbot website, located here: https://certbot.eff.org/lets-encrypt/debianstretch-nginx
I utilized the following backport sources:
deb http://deb.debian.org/debian stretch-backports main
deb-src http://deb.debian.org/debian stretch-backports main
I was able to hit the backports successfully when I would run apt-get update.
I was then able to install python-certbot-nginx by utilizing the following command:
apt-get -t stretch-backports install python-certbot-nginx
It is now successfully installed. If i try running the command from the website however, I still have the same error.
I am not that well versed in Linux, so maybe there is something I am missing. But it appears this was a formatting issue with the installation command. Someone can correct this if that is incorrect.
Thanks!
Z
