My domain is:https://erp.lifemakers.org
- sudo apt-get update
- sudo apt-get install software-properties-common
- sudo add-apt-repository universe
- sudo add-apt-repository ppa:certbot/certbot
sudo apt-get install certbot python-certbot-nginx
sudo certbot --nginx
My web server is (include version):odoo 13
The operating system my web server runs on is (include version):ubuntu 16.04
My hosting provider, if applicable, is:azure
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
it successfully installed but i found this messages
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
