Installing Certbot fails on Debian 9 using apt-get
www.davidsfolly.com/
sudo apt-get update
then:
sudo apt-get install python-certbot-apache -t stretch-backports
Reading package listsā€¦ Done
E: The value ā€˜stretch-backportsā€™ is invalid for APT::Default-Release as such a release is not available in the sources
Server version: Apache/2.4.25 (Debian)
Server built: 2017-09-19T18:58:57
Distributor ID: Debian
Description: Debian GNU/Linux 9.3 (stretch)
Release: 9.3
Codename: stretch
Linode
I can login to a root shell on my machine (yes or no, or I donā€™t know):
Yes
Iā€™m using a control panel to manage my site (no, or provide the name and version of the control panel):
No
First time user here. Assistance appreciated. Thanks.
Did you follow the instructions to add the stretch backports, as instructed on the certbot manual on Debian 9 for Apache?
Thank you Osiris! That solved the problem for me!!!
Iā€™m not sure how my eyes glossed over that line. The light-blue link didnā€™t help any. :blush:
What what things happen if I simply drop the -t stretch-backports?
The debian instructions would not apply to me, since Iā€™m actually using stretch via Raspbian (on a Raspberry Pi 3), and Raspbian does not have backports per https://www.raspberrypi.org/forums/viewtopic.php?t=190124
It probably wouldn't find the package you need.
I had to read it twice too :wink:
I went with the ā€œother unixā€ option.
