Certbot has problem setting up the virtual environment
solar.neroth.org (showing one of them, I have a few subdomains)
certbot-auto renew solar.neroth.org --standalone (usually I run without the specific subdomain to renew all)
[Very long output – including what I consider relevant, I can provide more if needed]
(During Bootstrapping dependencies, all modules are already the latest)
0 upgraded, 0 newly installed, 0 to remove and 19 not upgraded.
Creating virtual environment…
Installing Python packages…
Had a problem while installing Python packages
[pip prints a very long list of errors, showing the ending below… again can provide more if needed]
Requirement already satisfied: setuptools>=1.0 in /opt/eff.org/certbot/venv/lib/python2.7/site-packages (from josepy==1.1.0->-r /tmp/tmp.5hvrMhpImn/letsencrypt-auto-requirements.txt (line 87))
THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
pycparser==2.19 from https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl#sha256=344870c533812cb119c5475b5aed033ec546118711338ff9b2b78e67098d64e7 (from -r /tmp/tmp.5hvrMhpImn/letsencrypt-auto-requirements.txt (line 105)):
Expected sha256 a988718abfad80b6b157acce7bf130a30876d27603738ac39f140993246b25b3
Got 344870c533812cb119c5475b5aed033ec546118711338ff9b2b78e67098d64e7
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
Server version: Apache/2.4.25 (Raspbian)
Raspbian GNU/Linux 9 (stretch)
Linux 4.14.98-v7+ #1200 SMP armv7l GNU/Linux
None
Yes, that is from where the command was run. I have auto updated many times every 2-3 months without problems.
None
certbot-auto --version will trigger the same output as above
All my certificates are coming up for renewal. I just have/had enough knowledge to setup and run auto update from then. If you would like me to provide additional info, please tell me explicit linux commands or certbot commands
PS. Yes the OS packages have been updated with normal scripts after the last renewal.
It is ok by me, if I need to recreate all new certifiicates, but then I need to learn how to install the new ones… ( I have forgotten how I initially setup the certifiacte inside my server).
Hi @Cqc
that's a known problem. Please check
Juergen, Thank you very much for the very prompt response! Yes the solutions was trivial.
I am repeating it here for others quick reference. Read the above for details.
Just rename /etc/pip.conf (and delete it when you are satisfied everything works).
It worked well here on a Rasperry Pie 3.
I highly recommend, if possible, please add this one line summary as a possible solution at the messages that come up at the end of the current report when the script fails. It would reduce the future support workload for all… Thank you again!
