Renewal Error : Certbot has problem setting up the virtual environment
My domain is: www.cosmio.cl
I ran this command: ./certbot-auto renew
It produced this output: Certbot has problem setting up the virtual environment.
We wer not be able to guess the right solution from your pip output
My web server is (include version): Apache/2.4.33 (Unix)
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: AWS Lightsail
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): I am using control panel of AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot-auto
There’s an existing thread for this issue: Certbot has problem setting up the virtual environment
At the moment you’ll need to wait and see, there hasn’t been a workaround posted yet.
If you previously had certbot-auto working, you may be able to use --no-self-upgrade to work bypass the problem.
