Problem with certbot-auto renew
My domain is: gamesyap.com
I ran this command: certbot-auto renew
Processing /etc/letsencrypt/renewal/gamesyap.com-0001.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/techcomputerworld.com.conf
Processing /etc/letsencrypt/renewal/izquierdaanarkista.info.conf
Processing /etc/letsencrypt/renewal/gamesyap.com.conf
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/renewal.py”, line 64, in _reconstitute
renewal_candidate = storage.RenewableCert(full_path, config)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 461, in init
self._check_symlinks()
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 520, in _check_symlinks
“expected {0} to be a symlink”.format(link))
CertStorageError: expected /etc/letsencrypt/live/gamesyap.com/cert.pem to be a symlink
Renewal configuration file /etc/letsencrypt/renewal/gamesyap.com.conf is broken. Skipping.
/etc/letsencrypt/live/gamesyap.com-0001/fullchain.pem expires on 2019-03-04 (skipped)
/etc/letsencrypt/live/techcomputerworld.com/fullchain.pem expires on 2019-03-04 (skipped)
/etc/letsencrypt/live/izquierdaanarkista.info/fullchain.pem expires on 2019-03-06 (skipped)
No renewals were attempted.
Additionally, the following renewal configurations were invalid:
/etc/letsencrypt/renewal/gamesyap.com.conf (parsefail)
0 renew failure(s), 1 parse failure(s)
My web server is (include version): Nginx 1.14.0
The operating system my web server runs on is (include version): Ubuntu Server 18.04
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): no, Iuse command line interface for my server.
Hi @techcomputerworld
you have two different directories with the same domain name. And you have a valide Letsencryt - certificate:
CN=gamesyap.com 04.12.2018 04.03.2019 gamesyap.com, www.gamesyap.com - 2 entries
Keyalgorithm RSA encryption (2048 bit)
Signatur: SHA256 With RSA-Encryption
Serial Number: 0341197BB4890232876793DC2A5534A9AEC7
Thumbprint: 4ADB2294D5F58C4E880AEC623156C00BAEA8D873
So check your configuration with certbot certificates to find this valide certificate.
And delete the other certificate with
certbot delete --cert-name [name found in the other command]
thank you, i’ve tried
root@ubuntu:/etc/letsencrypt/live# certbot delete --cert-name gamesyap.com
Deleted all files relating to certificate gamesyap.com.
and I now execute command:
root@ubuntu:/etc/letsencrypt/live# certbot-auto renew
I think it works correctly, thank you for your help!, I learned something new today, regards.
Yep, your configuration looks good - Grade A - https://check-your-website.server-daten.de/?q=gamesyap.com
And your certificate is from 2018-12-04, so it's active.
