Auto-renewing failed - http-01 challenge for
blog.azee.se
./certbot-auto renew
Upgrading certbot-auto 0.22.2 to 0.26.0…
Replacing certbot-auto…
Creating virtual environment…
Installing Python packages…
Installation succeeded.
Processing /etc/letsencrypt/renewal/blog.azee.se.conf
http-01 challenge for blog.azee.se
Waiting for verification…
^CExiting abnormally:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1364, in main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1276, in renew
renewal.handle_renewal_request(config)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/renewal.py”, line 430, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1197, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 115, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/renewal.py”, line 312, in renew_cert
lineage.save_successor(prior_version, new_cert, new_key.pem, new_chain, config)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 1144, in save_successor
self.lineagename, self.archive_dir, symlinks, cli_config)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 189, in update_configuration
values = relevant_values(vars(cli_config.namespace))
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 244, in relevant_values
for option, value in six.iteritems(all_values)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 245, in
if _relevant(option) and cli.option_was_set(option, value))
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/storage.py”, line 226, in _relevant
plugins = plugins_disco.PluginsRegistry.find_all()
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/plugins/disco.py”, line 206, in find_all
plugin_ep = PluginEntryPoint(entry_point)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/plugins/disco.py”, line 52, in init
self.plugin_cls = entry_point.load()
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2290, in load
self.require(*args, **kwargs)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2307, in require
items = working_set.resolve(reqs, env, installer)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 824, in resolve
if req in processed:
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2893, in eq
self.hashCmp == other.hashCmp
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py”, line 653, in eq
elif isinstance(other, _IndividualSpecifier):
File “/opt/eff.org/certbot/venv/lib/python2.7/abc.py”, line 128, in instancecheck
def instancecheck(cls, instance):
KeyboardInterrupt
Apache 2.4.25
Debian 9.4
I’m using a control panel to managNoe my site (no, or provide the name and version of the control panel):NO
Your certbot-auto installation looks busted. Try fully removing it:
rm -rf /opt/eff.org/certbot
and run certbot-auto again.
Your data is perfectly safe (stored elsewhere in /etc/letsencrypt/)
Did you hit ^C? If so, why? Was it frozen or something?
