Certbot renew problem on some domain
My domain is:taldap.de
I ran this command:certbot-auto renew --dry-run --cert-name taldap.de
Processing /etc/letsencrypt/renewal/taldap.de.conf
http-01 challenge for taldap.de
http-01 challenge for www.taldap.de
Waiting for verification…
Challenge failed for domain taldap.de
Challenge failed for domain www.taldap.de
Attempting to renew cert (taldap.de) from /etc/letsencrypt/renewal/taldap.de.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/taldap.de/fullchain.pem (failure)
My web server is (include version):Server version: Apache/2.4.10 (Debian)
The operating system my web server runs on is (include version):Debian GNU/Linux 8 (jessie)
My hosting provider, if applicable, is:ovh.net
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.40.1
Hi @pauldon2
there are a lot of redirects to argusoft.de - https://check-your-website.server-daten.de/?q=taldap.de
Sample:
http://taldap.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
54.36.119.183
302
	http://www.argusoft.de/taldap.html.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
So it's impossible that Letsencrypt checks your validation file. Or runs argusoft.de on the same server?
Yes. This is the same sever.
But why is there such a curious redirect? It’s your software? Letsencrypt must find the validation file.
This is just another virtual server.
Please read some basics about challenge types.
You have to remove that curious redirect.
