My domain is:bokmanmd.com
I ran this command: sudo certbot-auto renew --dry-run --cert-name bokmanmd.com
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /etc/letsencrypt/renewal/bokmanmd.com.conf
http-01 challenge for bokmanmd.com
http-01 challenge for www.bokmanmd.com
Waiting for verification…
Challenge failed for domain bokmanmd.com
Challenge failed for domain www.bokmanmd.com
Attempting to renew cert (bokmanmd.com) from /etc/letsencrypt/renewal/bokmanmd.com.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/bokmanmd.com/fullchain.pem (failure)
Domain: bokmanmd.com
Detail: Invalid response from
http://bokmanmd.com/.well-known/acme-challenge/Ut7P1nI6OTJL26nw7ZN_tJwEG-oU-k_6behfyuvwdkw
[71.208.149.212]: “\n\n400 Bad
Request\n\nBad Request</h1”
Domain: www.bokmanmd.com
http://www.bokmanmd.com/.well-known/acme-challenge/IUn4wBgTvn5YUnn8pAUc-iJTJ5ecwwx1l3DGxlTVN1c
My web server is (include version):apache
The operating system my web server runs on is (include version):ubuntu 18.04.4
My hosting provider, if applicable, is: home network
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):1.5.0
- Content- and Performance-critical Checks
http://bokmanmd.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 71.208.149.212 400 Fatal: Check of /.well-known/acme-challenge/random-filename has a http status between 400 and 499, but not 404 - Not Found. Creating a Letsencrypt certificate via http-01 challenge may not work. Trouble creating a certificate? Use https://community.letsencrypt.org/ to ask.
http://www.bokmanmd.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 71.208.149.212 400 Fatal: Check of /.well-known/acme-challenge/random-filename has a http status between 400 and 499, but not 404 - Not Found. Creating a Letsencrypt certificate via http-01 challenge may not work. Trouble creating a certificate? Use https://community.letsencrypt.org/ to ask.
I don’t understand why it worked fine when I created the cert but now will not let me renew the same cert.
Also I just noticed the above is using HTTP:// for the acme-challenge. It must fail because my site redirects HTTP to HTTPS
