Problem renewing certificate
My domain is: services.barsupply.gr
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/services.barsupply.gr.conf
http-01 challenge for services.barsupply.gr
Waiting for verification…
Attempting to renew cert (services.barsupply.gr) from /etc/letsencrypt/renewal/services.barsupply.gr.conf produced an unexpected error: Failed authorization procedure. services.barsupply.gr (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://services.barsupply.gr/.well-known/acme-challenge/ovQi0X33G84eAGexvS0-OuGNYGvm3Z0pTcVkfQhTKbE [79.107.146.225]: “\r\n400 The plain HTTP request was sent to HTTPS port\r\n<body bgcolor=“white”>\r\n
400 B”. Skipping.
/etc/letsencrypt/live/services.barsupply.gr/fullchain.pem (failure)
    Domain: services.barsupply.gr
    Detail: Invalid response from
    400 B”
My web server is (include version): nginx version: nginx/1.10.3 “configured as reverse proxy”
Description: Debian GNU/Linux 9.9 (stretch)
Release: 9.9
SelfHosted
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): nope
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
Hi @nickrock
looks like you have a wrong port forwarding.
Port 80 extern -> port 443 intern.
That's wrong. That must be:
Port 80 extern -> port 80 intern.
Port 443 extern -> port 443 intern.
Yep, your port 80 is broken ( https://check-your-website.server-daten.de/?q=services.barsupply.gr ):
79.107.146.225 400 0.140 M
Bad Request
https://services.barsupply.gr/
79.107.146.225 200 0.800 N
Certificate error: RemoteCertificateChainErrors
https://services.barsupply.gr:80/
79.107.146.225 200 0.644 Q
Visible Content: Welcome to nginx! If you see this page, the nginx web server is successfully installed and working. Further configuration is required. For online documentation and support please refer to nginx.org . Commercial support is available at nginx.com . Thank you for using nginx.
http://services.barsupply.gr/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
79.107.146.225 400 0.183 M
Bad Request
Visible Content: 400 Bad Request The plain HTTP request was sent to HTTPS port nginx
Your https works. But your port 80 + https sends content:
That's wrong.
Hi @JuergenAuer
Ty for the help , it was a misconfiguration on my mikrotik router on nat port forwarding rule
i probably changed it when i was drunk or smt, cheers
problem is resolved.
