Certbot : "DNS problem: looking up A for my_domain: DNSSEC: RRSIGs Missing; no valid AAAA records found for my_domain
My domain is: joseldsm.com
I ran this command: sudo certbot --nginx joseldsm.com -d www.joseldsm.com
It produced this output: "DNS problem: looking up A for joseldsm.com: DNSSEC: RRSIGs Missing; no valid AAAA records found for joseldsm.com
(same for www.joseldsm.com)
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): Ubuntu
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I don't know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I'm trying to get the https certification. My domain works perfectly for the basic http : joseldsm.com and www.joseldsm.com.
Thanks ! :slight_smile:
Welcome @evol
Your DNS has a couple problems.
One is that the IP address in your A record is for a private IP address. That needs to be a public IP so the Let's Encrypt server can send your server an HTTP request to validate your cert request.
You say your site works on HTTP but it must work on the public internet. Not just your local network.
The other problem is the DNSSEC seems wrong on your DNS in general. I recommend disabling that first. Once you get a cert try to re-enable again. Sometimes that clears these up. Use the above Let's Debug test site to check after you re-enable it
https://dnsviz.net/d/joseldsm.com/dnssec/
Hello @MikeMcQ,
Thank you very much for your help. I just disabled DNSSEC for now. I didn't realize the IP adress was private. I really thought it worked on public internet.
I'll try to get a public adress instead then.
Thanks again !
I got a public IP and now it works ! Thanks a lot @MikeMcQ !
