Certbot fails with DNS problem
Guys, I have the trouble: user1@pythiadisco:~$ sudo certbot --nginx -d pythiadisco.ru -d www.pythiadisco.ru
Requesting a certificate for pythiadisco.ru and www.pythiadisco.ru
Domain: www.pythiadisco.ru
Type: dns
Detail: DNS problem: query timed out looking up A for www.pythiadisco.ru; DNS problem: query timed out looking up AAAA for www.pythiadisco.ru
user1@pythiadisco:~$ can you help me pls?
I moved your post into its own thread. We like each problem to have its own.
Had you posted in Help section to start you would have been shown the form below. Please answer as much as you can.
That said, the error message seems pretty clear. Let's Encrypt could not get an A and/or AAAA record in your DNS for your www subdomain name. At least one is required for an HTTP Challenge which the --nginx option uses.
Your apex domain is fine. It is just the www subdomain that fails. You could just add the missing A record to match your apex domain.
Normally when a record is missing your DNS server should reply NXDOMAIN. For some reason yours issues a SERVFAIL. So, that's something you should fix in your DNS config too. See, for example: www.pythiadisco.ru | DNSViz
You can also test your DNS with https://unboundtest.com
I got my certificate, thank for help it was fast and jut so helpful!
