Certbot DNS Problem Failed to Verify the temporary nginx
Good evening hope everyone is doing good. I am working on a school project and I keep bumping into this error when im running the last step before I get to see my actual website. If this help im making an image board for my class. I was inspired by this, Vichan it has all the code. I appreciate everyone for trying to help.
My domain is: www.chan.fig.org
I ran this command: certbot --nginx -d chan.fig.org
Requesting a certificate for chan.fig.org
Domain: chan.fig.org
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for chan.fig.org - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for chan.fig.org - check that a DNS record exists for this domain
My web server is (include version): Did not get that far
The operating system my web server runs on is (include version): Debian
Hi @Iluvbrad,
Before using Certbot, you should get your site up and running using HTTP. That is the expectation that Certbot has (at least when run with the most popular --nginx and --apache modes!), that it will be run on a server where you already have a working HTTP site that's accessible under your domain name. Then it can help add HTTPS to that site.
