Getting SERVFAIL (A) when using certbot --nginx
My domain is: jaeyson.dev
I ran this command: sudo certbot --nginx
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): jaeyson.dev
Requesting a certificate for jaeyson.dev
  Domain: jaeyson.dev
  Type:   dns
  Detail: DNS problem: SERVFAIL looking up A for jaeyson.dev - the domain's nameservers may be malfunctioning
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Ubuntu 20.04.1 LTS (focal)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.19.0
i've also checked these:
bought the domain from porkbun. it has dnssec which i havent touched it. anything that i missed?
DNSSEC is enabled on the domain but isn't setup on the Porkbun nameservers. This makes the domain unresolveable.
The first thing you'll probably want to do is login to your domain registrar (Porkbun I guess) and disable DNSSEC.
You may need to wait a little while after that, then you should be able to issue a certificate.
Finally, you can try to enable DNSSEC again if you want, carefully following the instructions. Hopefully it goes better the second time.
deleting DNSSEC Record helped. Thanks alot @_az :+1:
Alternatively, you could get DNSSEC working properly. With a recent version of bind9 (i.e. 9.16+), it's really easy (just add "dnssec-policy default;" to the zone {} stanza), and porkbun have good support for it. It's easy to upload the DS record there after bind9 has created the corresponding CDS record. By the way, it looks like DNSSEC might still be partially set up but very bogus for your domain. You can see this with jaeyson.dev | DNSViz
hi @raf, i've rescanned again (jaeyson.dev | DNSViz), this is what i saw.
hmmm, still confused with bind9 actually (im new with all those stuffs so i have to do some homework)
That's just saying that there is no DNSSEC now. Which is fine. You don't need DNSSEC for LetsEncrypt. But if you want to setup DNSSEC, and you already use bind9.16+, it has become incredibly easy. I recommend reading DNSSEC Guide — BIND 9 documentation and subscribing to the bind users mailing list if you need help, but the short version is: add "dnssec-policy default;" to your zone {} stanza, monitor your zone to see when bind9 creates the CDS record (e.g. run "host -t cds jaeyson.dev" daily until something appears), upload the data in the CDS record to porkbun's website. They have a knowledge base article showing where to do that. Then tell bind9 that it's done with "rndc dnssec -checkds -key ID published jaeyson.dev" (where the ID is the first number in the CDS record data). Then check it with dnsviz.net.
