DNS problem: looking up A for trosen.defman.no: DNSSEC: RRSIGs Missing; no valid AAAA records found for trosen.defman.no
My domain is: trosen.defman.no
I ran this command: /usr/bin/certbot -v renew
Processing /etc/letsencrypt/renewal/trosen.defman.no.conf
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for trosen.defman.no
http-01 challenge for trosen.defman.no
Challenge failed for domain trosen.defman.no
Domain: trosen.defman.no
Type: dns
Detail: DNS problem: looking up A for trosen.defman.no: DNSSEC: RRSIGs Missing; no valid AAAA records found for trosen.defman.no
Failed to renew certificate trosen.defman.no with error: Some challenges have failed.
/etc/letsencrypt/live/trosen.defman.no/fullchain.pem (failure)
nginx version: nginx/1.18.0 (Ubuntu)
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
fastname.no
Yes
No
certbot 2.10.0
Hmm. Unboundtest agrees that it isn't getting the signatures, but DNSViz seems to see them. There's something odd going on but I don't know as I'll be able to help.
Can you share more about how your DNS is set up? Have you just recently enabled DNSSEC? It looks like you've been getting certs successfully for quite a while, has anything else changed in the last few months on your side? Let's Encrypt has added more validation perspectives recently, but I don't think that's related here.
It seems the IP is within the block 100.64.0.0/10
[SHARED-ADDRESS-SPACE-RFC6598-IANA-RESERVED]
Let's Debug (letsdebug.net)
Ah! That's almost definitely it. The Unbound config is stripping the private IP from the response, which is why the DNSSEC is broken. This is one of the times that the error message is very misleading.
You need a public IP in order to use HTTP-01 (and for the public to visit the site). If it's intended to be a private server, then you need to switch to DNS-01.
a.k.a.
CGNAT
Asking my ISP to move me to a loopback where I would receive a public dhcp solved the problem
