Renewal issue with DNS
My domain is: who-analytics.net whn-analytics.net
I ran this command: sudo certbot -n -d whn-analytics.net --nginx --agree-tos --email olha@necsi.edu certonly --force-renew
Renewing an existing certificate for whn-analytics.net
Domain: whn-analytics.net
Type: dns
Detail: DNS problem: looking up A for whn-analytics.net: DNSSEC: Bogus: validation failure <whn-analytics.net. A IN>: signature crypto failed from 2600:9000:5307:9900::1; DNS problem: looking up AAAA for whn-analytics.net: DNSSEC: RRSIGs Missing: validation failure <whn-analytics.net. AAAA IN>: no signatures from 2600:9000:5300:f600::1
The operating system my web server runs on is (include version): AWS Linux
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.10.0
There seems to be an issue with a missing glue record:
[see: whn-analytics.net | DNSViz]
Furthermore, no major DNS provider can determine who the authoritative servers are for your domain:
nslookup -q=ns who-analytics.net 1.1.1.1
nslookup -q=ns who-analytics.net 8.8.8.8
nslookup -q=ns who-analytics.net 9.9.9.9
All return:
can't find who-analytics.net: Non-existent domain
Even worse...
The root servers for .net [TLD] aren't showing any authoritative nameservers for your domain:
nslookup -q=ns who-analytics.net a.gtld-servers.net
Returns:
So...
It seems that your domain may have been de-registered recently.
Not sure which was the typo. The who as the domain name or the whn in all the command examples :person_shrugging:
yes, it should be
whn-analytics.net
Do you think it is problem with AWS Route 53? Or is it something I can fix on my ec2 server?
I see this https://www.ssllabs.com/ssltest/analyze.html?d=whn-analytics.net
Edit
And this https://dnsspy.io/scan/whn-analytics.net
Edit
and https://lookup.icann.org/en/lookup shows
I have these records set up in Route 53.
Do I have to add a DS record?
There is no option to add DNSKEY. But it shows that there is one...
Could it be a problem with www.conf?
Try deleting the IPv6 DNS AAAA records.
and delete the IPv4 DNS A records except for the only keep the DNS A record containing the IPv4 Address of 52.91.16.99
As LE prefers IPv6 over IPv4.
Hi @olha,
The online tool Let's Debug yields these results for the HTTP-01 challenge https://letsdebug.net/whn-analytics.net/2150258
ReservedAddress
Fatal
A private, inaccessible, IANA/IETF-reserved IP address was found for whn-analytics.net. Let's Encrypt will always fail HTTP validation for any domain that is pointing to an address that is not routable on the internet. You should either remove this address and replace it with a public one or use the DNS validation method instead.
127.0.0.1
ReservedAddress
Fatal
172.31.18.205
eservedAddress
Fatal
2001:db8:85a3::8a2e:370:7334
Thanks a lot! The certifacate was renewed! I removed 127.0.0.1 and 172.31.18.205.
As to 2001:db8:85a3::8a2e:370:7334, I am not sure what to replace it with.
Ok. There are suggestions at Route 53 for how to fix 2001:db8:85a3::8a2e:370:7334 line. I will do it.
Nothing.
It did not allow me to have an empty field. I removed the AAAA record and now it is fine. AAAA required iPv6 address which was for a private cloud. I did not have one.
