DNS nameserver propogation issue
aarongray.org @ ns1.hover.com
sudo certbot --nginx -d aarongray.org,www.aarongray.org
[sudo] password for aaronngray:
Requesting a certificate for aarongray.org and www.aarongray.org
Domain: aarongray.org
Type: dns
Detail: DNS problem: looking up A for aarongray.org: DNSSEC: DNSKEY Missing; DNS problem: looking up AAAA for aarongray.org: DNSSEC: DNSKEY Missing
Domain: www.aarongray.org
Type: dns
Detail: DNS problem: looking up A for www.aarongray.org: DNSSEC: DNSKEY Missing; DNS problem: looking up AAAA for www.aarongray.org: DNSSEC: DNSKEY Missing
nginx/1.18.0
Armbian 22.11.0-trunk Bullseye with Linux 6.4.12-edge-sunxi
homeserver @ 81.174.241.153
no, ssh/bash
certbot 2.8.0
I changed the IP to 212.159.110.144 temporarily to see how it was propagating, I have changed it back to 81.174.241.153.
This isn't related to "propogation" (that generally isn't a problem because Let's Encrypt queries your authoritative servers directly), but that your registrar claims that your domain is DNSSEC-signed but your DNS server isn't signing anything.
First you need to get your domain name working, before you worry about trying to get a certificate for it.
For those that like to see things drawn out:
aarongray.org | DNSViz
I have two other domains that work fine on HOVER, they don't have DNSSEC keys, so I have deleted the DNSSSEC key, but am getting the same result.
The same error message too? Because I don't see the DNSSEC error anymore on dnsviz or reported by Let's Debug. Please show the error message
All working now !
You need to figure out how to do DNSSEC correctly [and do that right].
