Hello there,
First of all, sorry for my bad english!
I’m configuring my website through plesk-panel.
For a few month now, I changed my website to build with adobe portfolio.
To ensure, my domainname synchronizes with the portfolio-website, I had to change the ip-adress.
So in short summary. My Plesk-Configuration IP is different than my website IP.
When I want to renew my certificate in the plesk-panel, it shows a message, that it has to be the same ip-adress…
Hello Stevenzhu,
Thank you so much for your help! Well, it worked!
Just had to unlink and relink the domainname to the myportfoliosite inside myportfoliosettings.
Easy solution, but hard to think about that little step.
Thank you alot!
