Hi thank you for reply,
I set the record AAAA after the certificate had not already been renewed. I read a post that said to set also the aaaa record with ipv6. So I try it. But the problem there was already before. The first email that reported the problem is March 6th:
Data: 6 marzo 2018 05:28:07 CET
Could not secure domains of Administrator (login admin) with Let’s Encrypt certificates. Please log in to Plesk and secure the domains listed below manually. Securing of the following domains has failed:
The following domains have been secured without some of their Subject Alternative Names:
Could not renew Let’s Encrypt certificates for Administrator (login admin). Please log in to Plesk and renew the certificates listed below manually. Renewal of the following Let’s Encrypt certificates has failed:
The following Let’s Encrypt certificates have been renewed without some of their Subject Alternative Names:
Legend: [+] This domain is secure. The domain’s SSL/TLS certificate from Let’s Encrypt has been issued/renewed. [-] This domain is not secure. Either the domain’s SSL/TLS certificate from Let’s Encrypt could not be issued/renewed or the domain name was excluded from the certificate. Renew the certificate manually or request a new one to secure this domain.
before this email the certificate has always been renewed and I have not changed any DNS settings. I pointed a redirect towards a subdomain cocin.pixelcreative.it. Probably is here the problem.
