Bypass rate limit
hostcraft.org
certbot certonly -d panel.hostcraft.org
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: panel.hostcraft.org: see https://letsencrypt.org/docs/rate-limits/
Nginx (certbot)
Ubuntu 18.04
Cloudflare
no
0.31.0
Hi @kiityman1
you have created 5 identical certificates.
Please use one of these instead of creating a new certificate.
Is there anywhere I can download them?
I had to reset my server and lost the files :frowning:
If you have deleted the private keys, you can't use only the public part.
Creating files -> make a backup -> if not and if you hit the limit, you have a problem.
You need to wait until August 4th Let's Debug Toolkit
In what world does a "reset" result in that kind of data loss? Or do you mean format/reinstall that kind of thing?
