Blogger custom domain doesn't work with https! How can I fix it?
Dear Support,
I read that you can help me do the https settings for my custom url on blogger. https://support.google.com/blogger/answer/6284029?hl=en
So I have problems with https. It is not working.
I have bought a custom domain from www.namecheap.com.
(Date: 01.10.2020.)
My blog URL: www.123systems.blosgspot.com
My purchased custom domain: www.123systems.com
(„123” tag means a private part of the address, not promoting anything.)
I am from Hungary, so the text on the attached images are in Hungarian, but everything is clear, I translated and signed with colour every important things.
I uploaded the pictures to my DRIVE folder:
  1. Image #01a,b: I have done the Blogger integration. It is OK.
  2. Image #02: I have done the host settings on Namecheap interface. It is OK.
  3. Image #03: So Blogger url redirected to custom domain successfully, but there is no https! NOT OK!
  4. Image #04-a,b: On Blogger interface if I turn on the HTTPS option, the website became unavailable!
How can I activate the HTTPS / SSL protocol for my custom URL / DOMAIN?
Regards,
Istvan
Welcome to the Let's Encrypt Community, Istvan :slightly_smiling_face:
I recommend you start with the basics.
Hello Everybody,
My issue solved! :slight_smile:
The main problem was that Blogger has no instruction information what to do / how much time should wait.
So after you purchase a custom domain from a third party service and integrated it to your Blogger interface:
  1. You have to wait 12-24 hours.
  2. Then a notification is appear at the top of your Blogger interface: "HTTPS available".
  3. Then you can turn on HTTP. It will be in "PENNDING" status.
  4. You have to wait anither12-24 hours.
  5. HTTPS redirection will be active, you can turn on.
  6. Your site will be validated for HTTPS.
