Need certificate for blogger blog with custom domain
My domain is: anglindairy.net
My web server is (include version): blogger
The operating system my web server runs on is (include version):Windows 10
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I don't know
Welcome to the Let's Encrypt Community, Susan :slightly_smiling_face:
Please start here:
https://support.google.com/blogger/answer/6284029?hl=en
I tried your suggestion but it failed with a message that I did not have the authority. Does it take time for Blogger to know I have contacted Let's Encrypt?
I'm not sure what you mean by that latter part, but opening a thread on this Community doesn't influence anything at the Let's Encrypt side of things: Let's Encrypt is fully automated, nothing manually to be done. So this thread doesn't make any difference.
Further more, I see some "irregularities" with your current setup:
  • Your hostname resolves to the IP address 72.167.120.230 which is not a Google IP address (Blogger is a Google service), but a GoDaddy IP address;
  • The IP address 72.167.120.230 is not reachable on port 80 nor port 443, so browsers can't connect to it at all: your site is down.
@srta
It appears to me that:
Your domain registrar is: eNom
Your hosting provider is: GoDaddy
You need to point anglindairy.net to blogger.
Addresses: 2607:f8b0:4008:802::2013
           172.217.8.115
Aliases:   www.anglindairy.net
blog.anglindairy.net
Non-existent domain
blogger.anglindairy.net
Non-existent domain
FTI: It is quite difficult to CNAME a domain name ("anglindairy.net").
That's absolutely correct, @rg305. Some decisions need to be made as to where the blog will live.
You are speaking to a tech limited person. I am not sure where I go from here.
How do I point anglindairy.net to blogger
Hi @srta,
Did you see @griffin's link above to this guide?
This describes how to change your DNS records at eNom in order to point your domain to Blogger. (I haven't verified the content myself, but that appears to be what it's explaining how to do.)
