BigBlueButton Installation
My domain is:bbb.claremontbs.co.zw
I ran this command:wget -qO- https://raw.githubusercontent.com/bigbluebutton/bbb-install/v3.0.x-release/bbb-install.sh | bash -s -- -w -v jammy-300 -s bbb.claremontbs.co.zw -e owenm@claremontbs.co.zw -g
It produced this output: Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
Domain: bbb.claremontbs.co.zw
Detail: 2a02:4780:4c:4218:7855:6f5f:20a9:17d5: Invalid response from http://bbb.claremontbs.co.zw/.well-known/acme-challenge/0T5WNvdcUd1U3Q22TQCjkr5Y_NyUKW1BSBmb_9iVf-M: 404
bbb-install: Let's Encrypt SSL request for bbb.claremontbs.co.zw did not succeed - exiting
My web server is (include version): Ubuntu 22.04 x86_64
The operating system my web server runs on is (include version):Ubuntu 22.04 x86_64
My hosting provider, if applicable, is: Hostinger
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):N/A
Does this IPv6 belong to your server?
Is BBB listening on it?
how do i check that?
You run the ip addr command, assuming there's no NAT in front of it (there shouldn't be)
I see two IPv4 and two IPv6 in your DNS records, tho. Is that intended or is one pair left behind from a previous config?
Hi guys, thank you so much, i had forgotten to point my domain to the VPS.
