hi,
one of the clients has run a security scan for the site web that I am working on, so he found some issues that I need to fix, I don’t know if they are related to Plesk or to Let’s encrypt
My domain is: techno-web.tech
these issues are :
FTP Unencrypted Cleartext Login
// solution: Enable FTPS or enforce the connection via the ‘AUTH TLS’
SMTP Unencrypted Cleartext Login
//solution: Enable SMTPS or enforce the connection via the ‘STARTTLS’ command
POP3 Unencrypted Cleartext Login
//solution:
Configure the remote server to always enforce encrypted connections via SSL/TLS with the ‘STLS’ command
SSL/TLS: Diffie-Hellman Key Exchange Insufficient DH Group Strength Vulnerability…
//solution:
Deploy (Ephemeral) Elliptic-Curve Diffie-Hellman (ECDHE) or use a 2048-bit or stronger Diffie-Hellman group
I have been searching how to apply these solutions so long but I could not find a way if anyone knows how I would be grateful
I am using Plesk onyx, Nginx with a user account
My web server is (include version): Plesk Onyx 17.8.11
The operating system my web server runs on is (include version): windows 10
My hosting provider, if applicable, is: ovh
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):yes
or certbot-auto --version
if you’re using Certbot):
