After revoking problem with renewal
I used this command before revoking:
certbot certonly --server https://acme-v02.api.letsencrypt.org/directory --account 9c413790cb5cc29a0fafd2c2d1a379b4 --cert-name mail.motogb.co.uk -d mail.motogb.co.uk -d mail.benelli.co.uk -d mail.boltonmotorcycles.co.uk -d mail.chorleyyamaha.co.uk -a webroot -w /var/www/vhosts/motogb.co.uk/default.motogb.co.uk/webroot
Now I receive message for each domain
Domain: mail.motogb.co.uk
Detail: Invalid response from
https://mail.motogb.co.uk/.well-known/acme-challenge/kbuSBPuZNhadZI033UZKptVNnyJIsbDvnZo4cOEr640
[2a02:22d0:5:ec01:185:216:76:98]: “\n\n404 Not
Found\n<BASE href=”/error_docs/">\n\n\n
No"
I haven’t hosting for mail.domain.
How can I resolve it? Please help
Your problem is not related to your revoking (that was probably ill advised).
Did that command work before?
Are you suer that’s the right directory? (you can also use other plugins for authentication, like -a apache)
thanks Speppe :slight_smile: that was it
Yes, this command work before.
I supposed so, but it ultimately depends on your setup.
