Problème de renouvellement
My domain is: tiimster.com
/opt/letsencrypt# certbot-auto renew
Processing /etc/letsencrypt/renewal/tiimster.com.conf
http-01 challenge for tiimster.com
Waiting for verification…
Challenge failed for domain tiimster.com
Attempting to renew cert (tiimster.com) from /etc/letsencrypt/renewal/tiimster.com.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/tiimster.com/fullchain.pem (failure)
My web server is (include version): Apache/2.4.25 (Debian)
The operating system my web server runs on is (include version): Debian GNU/Linux 9
My hosting provider, if applicable, is: VPS chez OVH
I can login to a root shell on my machine (yes or no, or I don’t know): oui
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): non
certbot 0.36.0
Hi @mowebius
you use the apache-authenticator. That creates a temporary location definition in another directory. Looks like there is no access to read that directory.
Run Certbot with the -vvv flag to find that directory. Then create it (if it doesn't exist) and add the permissions.
Or find your webroot (DocumentRoot in your vHost) of your https vHost, then use that - https://check-your-website.server-daten.de/?q=tiimster.com
• http://tiimster.com/
51.254.214.190 301 https://tiimster.com/ 0.054 A
• http://www.tiimster.com/
51.254.214.190 301 https://tiimster.com/ 0.053 E
• https://www.tiimster.com/
51.254.214.190 302 https://tiimster.com/ 3.253 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
• https://tiimster.com/
51.254.214.190 200 3.610 N
Certificate error: RemoteCertificateChainErrors
• http://tiimster.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
51.254.214.190 301 https://tiimster.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.067 A
Visible Content: Moved Permanently The document has moved here . Apache/2.4.25 (Debian) Server at tiimster.com Port 80
• http://www.tiimster.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
51.254.214.190 301 https://tiimster.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.054 E
Visible Content: Moved Permanently The document has moved here . Apache/2.4.25 (Debian) Server at www.tiimster.com Port 80
• https://tiimster.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 404 3.166 N
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.25 (Debian) Server at tiimster.com Port 443
http + /.well-known/acme-challenge/random-filename is redirected to https, so you must use your https DocumentRoot.
certbot run -a webroot -i apache -w yourDocumentRoot -d tiimster.com -d www.tiimster.com
Now you have a certificate only with the non-www domain name. So your existing www version has the wrong certificate.
Thanks for your answer,
First, you said : "Run Certbot with the -vvv flag to find that directory"
I'm a simple developer and I'm not comfortable with server managing.
So, could you explain in details the syntax of the certbot command for finding that temporary directory's location
Second, here's my virtual host's file. Is there anything to change.
<VirtualHost *:443>
  # NOM & ADMIN
  ServerName tiimster.com
  ServerAdmin (masked)
  # EMPLACEMENT
  DocumentRoot /var/www/tiimster.com
  <Directory />
     Order Deny,Allow
     Deny from all
     Options -Indexes -Includes -ExecCGI -FollowSymlinks
  </Directory>
  <Directory /var/www/*>
     Order allow,deny
     Allow from all
     AllowOverride All
     Options -Indexes -Includes -ExecCGI +FollowSymlinks
  </Directory>
  # ERROR LOGS
  ErrorLog ${APACHE_LOG_DIR}/tiimster.com-error.log
  CustomLog ${APACHE_LOG_DIR}/tiimster.com-access.log combined
  # REDIRECTION - Les lignes commentées sont générées par letsencrypt
  SSLCertificateFile /etc/letsencrypt/live/tiimster.com/fullchain.pem
  SSLCertificateKeyFile /etc/letsencrypt/live/tiimster.com/privkey.pem
There
is your DocumentRoot. So use it.
And read
https://certbot.eff.org/docs/using.html
to see the command line options you can use.
Thx again,
Last question : If problem not solve, is it possible to revoke certificate before making a new demand
Please read
Revoking certificates does not reset rate limits , because the resources used to issue those certificates have already been consumed.
