Renewal Problem
My domain is: nchanga.com
I ran this command:certbot certonly -a webroot --webroot-path=/usr/share/nginx/html -d nchanga.com -d www.nchanga.com -d mail.nchanga.com
root@mail:/etc/letsencrypt/renewal# certbot certonly -a webroot --webroot-path=/usr/share/nginx/html -d nchanga.com -d www.nchanga.com -d mail.nchanga.com
http-01 challenge for nchanga.com
http-01 challenge for www.nchanga.com
http-01 challenge for mail.nchanga.com
Using the webroot path /usr/share/nginx/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. nchanga.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://mail.nchanga.com/.well-known/acme-challenge/IRvxHWEAZHs934Vi7vR0KJj3lXiN7u_PgvBNIs_dbgs [155.93.238.213: “\r\n404 Not Found\r\n<body bgcolor=“white”>\r\n
404 Not Found
\r\n
”, www.nchanga.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://mail.nchanga.com/.well-known/acme-challenge/Qd5qQvnsrT5esk4XCix03iHpcf4fTC3Tq1q2MQiCX9w [155.93.238.213: “\r\n404 Not Found\r\n<body bgcolor=“white”>\r\n
404 Not Found
\r\n
”, mail.nchanga.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://mail.nchanga.com/.well-known/acme-challenge/Q3KdIu1Ns7yugBE9ehXhbb-DTHKKVxMGKAbuODMi–8 [155.93.238.213: “\r\n404 Not Found\r\n<body bgcolor=“white”>\r\n
404 Not Found
\r\n
Domain: nchanga.com
Detail: Invalid response from
404
Not Found
\r\n
Domain: www.nchanga.com
404
Not Found
\r\n
Domain: mail.nchanga.com
404
Not Found
\r\n
The operating system my web server runs on is (include version): rasbian
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): no result.
The strange thing this was working for ages, auto-renewing like clockwork. Nothing has changed.
Hi @chewiesw
simple answer: If webroot doesn't work, your webroot is wrong.
Checking your first domain there are redirects to mail... https://check-your-website.server-daten.de/?q=nchanga.com
What says
nginx -T
Wow thanks for the quick response. You are indeed correct my webroot was wrong. I managed to generate a new cert. Will auto-renew no resume working?
Thank you
Check your Certbot config files. There the new webroot should be visible.
