Trouble renewing cert - no webroot?
control.example1.com
/usr/local/bin/certbot-auto certonly -d control.example1.com --nginx
http-01 challenge for control.example1.com
Using default address 80 for authentication.
nginx: [warn] duplicate MIME type “text/html” in /etc/nginx/nginx.conf:32
Waiting for verification…
Challenge failed for domain control.example1.com
nginx: [warn] duplicate MIME type “text/html” in /etc/nginx/nginx.conf:30
Not Found
\r\n”To fix these errors, please make sure that your domain name was
nginx/1.16.1
centos 7
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 1.6.0
It’s pretty hard to help you with a redacted domain.
Are you using Cloudflare (CDN, not just DNS) by any chance?
Ah, understood. No, we’re not currently using cloudfare.
To provide more background info, nginx was migrated over to to this box from a box that has since been deleted. I’ve also tried using -webroot but the webroot I see in the nginx config doesn’t exist on this box.
It appears the auto-renew did work. Thank you!
