A problem with trying to setup a SSL certificate Invalid Domain issue
My domain is: https://panel.jumblepterodactyl.org/
acme.sh --issue --dns dns_cf -d "panel.jumblepterodactyl.org" --server letsencrypt --key-file /etc/letsencrypt/live/panel.jumblepterodactyl.org/privkey.pem --fullchain-file /etc/letsencrypt/live/panel.jumblepterodactyl.org/fullchain.pem
It produced this output: Invalid Domain Error adding TXT record to domain: _acme-challenge.panel.jumblepterodactyl.org
My web server is (include version): ?
The operating system my web server runs on is (include version): ?
My hosting provider, if applicable, is: Cloudflare
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Hello I am new to Ubuntu (I just installed it like 10 hours ago) I wanted to try the pterodactyl thing for server hosting so I did it all worked good until I got to the SSL Certificate part I did buy a website from cloud flare but I have no clue how web siting works I did make a subdomain with the name of panel but the problem is I have no clue what IP to put or where to find it but I tried my public IP didnt work and some other ips on my network I think the problem is the IP i am not sure but every time I try to run that command it just outputs invalid domain I looked all over google and I am lost so this is my last resort I wanted to avoid asking people for help because I am brand new at all this stuff and don't want to be a burden but I have no clue what else to do I am not sure what else I need to add but if anyone requests something ill send it
Did you follow the steps for acme.sh Cloudflare setup here?
The DNS Challenge, which is what you are doing with the dns-cf mode uses a DNS TXT record to prove your control of the domain name. The public IP address of your server is not involved with this kind of challenge.
Just in case you haven't yet ... you should review this:
