123-reg and SSL
my domain is:www.seaglassandwaves.co.uk
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): I get https://www.123-reg.co.uk/secure/cpanel/ssl
I need to install an SSL certificate. The host is https://www.123-reg.co.uk/
However its does not appear to be that easy! 123_reg are not supplying me with info!
Any ideas ??
Thanks in advance…
they use Cpanel, so unless your provider explicitly try to screw you by disabling it, link below should apply
Cheers! Will give this a go. I may have to badger 123-reg to get this on the cPAnel but fingers crossed!
