How do I start?
Sorry for such a basic question, this is my first time installing SSL. My webserver gave me a CSR and told me to give this to Let’s Encrypt to get the certificate and Private Key. How do I do this? I provided a server information screen shot below. Thank you.
lottelehmannleague.org
none
none
I don’t know
See screenshot below
Site5
No, using Shared Hosting
cPanel 70.0 (build 69)
I don’t know
Hi @Suchi
if you use shared hosting and cPanel, then check your cPanel if there is an integrated solution.
If yes, that's the best option.
Then you don't need an own client. And you may not install an own created certificate.
But that's not required if your cPanel supports Letsencrypt certificates.
Thank you for replying. I contacted my web server and asked if they support Let’s Encrypt. They said yes, but I have to get the certificate myself, and then they will help install it. Then gave me a CSR and told me to give it to Let’s Encrypt to get a SSL certificate and Private Key. They told me to download those files when I get them, and then upload them to my home directory on the server. Am I supposed to use certbot?
This is not a recommended way to use Let's Encrypt. The suggested way to use it is with automated client software, normally running on the web server itself.
There are ways that you can use a CSR to get a Let's Encrypt certificate, but all Let's Encrypt certificates are valid for only 90 days, so you would have to repeat the process frequently and would probably not have a good experience.
Typically, only the system administrator of the server can usefully install a client like Certbot on the server, so this isn't a convenient solution for shared hosting environments.
Instead of using the CSR to obtain the certificate manually, I would suggest one of
  • getting your web host to add native Let's Encrypt support,
  • switching web hosts to one with better Let's Encrypt support, or
  • buying a paid certificate from another CA.
I see. Thank you for taking the time to explain. When I asked my server customer support if they supported Let’s Encrypt, they said yes – so I assumed they would manage the whole thing. You are correct, I don’t want to go through this every 90 days. I will check back with them with the feedback you provided. Thank you again.
You can compare with
Most providers listed here support Let's Encrypt automatically, without requiring the subscriber to do anything. The ability to import an externally-obtained certificate doesn't quite rise to the level of "support" by the standards of this list. :slight_smile:
Understood. Looks like I will simply have to pay for a certificate. I just finished chatting with my server and they confirmed they can only install a certificate that I obtain, and then repeat as needed.
Thank you again.
