Wordpress Litespeed SSL is not renew
My domain is: compassdpo.com.br
I ran this command:sudo certbot renew -v
Processing /etc/letsencrypt/renewal/compassdpo.com.br-0001.conf
Processing /etc/letsencrypt/renewal/compassdpo.com.br.conf
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for compassdpo.com.br and www.compassdpo.com.br
http-01 challenge for www.compassdpo.com.br
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain www.compassdpo.com.br
Domain: www.compassdpo.com.br
Detail: 169.57.169.74: Invalid response from http://www.compassdpo.com.br/.well-known/acme-challenge/8jDirJOIo2tGjfpz1UfnHpG6oMWMG1-3SlQFgjJpwTY: 404
Failed to renew certificate compassdpo.com.br with error: Some challenges have failed.
The following certificates are not due for renewal yet:
/etc/letsencrypt/live/compassdpo.com.br-0001/fullchain.pem expires on 2024-06-09 (skipped)
/etc/letsencrypt/live/compassdpo.com.br/fullchain.pem (failure)
systemd 249 (249.11-0ubuntu3.11)
Linux
Digital Oean
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I can access via wordpress or ssh root
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
Welcome @MarcosClimby
You should check the DNS A record for your www subdomain. It points to an nginx server not LiteSpeed. And is a different IP than for your base name. Usually those two IP addresses are the same.
Request to: www.compassdpo.com.br/169.57.169.74, Result: [Address=169.57.169.74,Address Type=IPv4,Server=nginx
Request to: compassdpo.com.br/134.122.5.165, Result: [Address=134.122.5.165,Address Type=IPv4,Server=LiteSpeed
Hi MikeMcQ, thanks for your reply.
I have checked my DNS and server address and everything is configured pointing to ip 134.122.5.165.
Could ip address 169.57.169.74 something internal from Digital Ocean?
Not exactly.
Your www FQDN is using an incorrect CNAME [with a TYPO/misspelling]:
Address: 134.122.5.165
Name:    compass.com.br     <<<<< should be "compassdpo.com.br"
Address: 169.57.169.74
Aliases: www.compassdpo.com.br
Thank you @rg305! My fault. I have corrected the DNS.
Do I need to wait to repeat the process to renew the SSL?
No, Let's Encrypt queries the authoritive DNS servers directly. It is not affected by TTL propagation
Hello experts, it is me again! After correct the DNS I applied sudo certbot renew which sent me the following message:
/etc/letsencrypt/live/compassdpo.com.br/fullchain.pem expires on 2024-06-10 (skipped)
No renewals were attempted.
However when I tried to access the landing page: https://compassDPO.com.br it was showing not secured. Then I applied the command: sudo certbot renew --dry-run
The following message appears:
Simulating renewal of an existing certificate for compassdpo.com.br
Failed to renew certificate compassdpo.com.br-0001 with error: Missing command line flag or config entry for this setting:
Input the webroot for compassdpo.com.br:
Simulating renewal of an existing certificate for compassdpo.com.br and www.compassdpo.com.br
The following simulated renewals succeeded:
/etc/letsencrypt/live/compassdpo.com.br/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/compassdpo.com.br-0001/fullchain.pem (failure)
Any suggestion on how to solve this issue?
Many thanks!
You definitely got a new cert with your basename and its www subdomain dated today.
So, check your LiteSpeed configuration and make sure it refers to the cert files in the /etc/letsencrypt/live/compassdpo.com.br folder for the cert you got today
You can see your cert details with. Please show this so we can also fix the problem with the -0001 cert profile
sudo certbot certificates
Thanks Mike! I got the the following answer (which I understood was ok):
Found the following certs:
Certificate Name: compassdpo.com.br-0001
Serial Number: 3adc700f5cba73e4f27dd8c4a56d7d386cf
Key Type: RSA
Domains: compassdpo.com.br
Expiry Date: 2024-06-09 10:37:18+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/compassdpo.com.br-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/compassdpo.com.br-0001/privkey.pem
Serial Number: 4d80bef80c7d3051c7739d7e11a1110facd
Key Type: RSA
Domains: compassdpo.com.br www.compassdpo.com.br
Expiry Date: 2024-06-10 06:22:52+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/compassdpo.com.br/fullchain.pem
Private Key Path: /etc/letsencrypt/live/compassdpo.com.br/privkey.pem
I am sorry to ask but do you know how to check if LiteSpeed configuration refers to the cert files?
I am not expert at LiteSpeed. There are various ways to manage it.
Do you remember how you configured it originally? Because it is using a Let's Encrypt cert but one dated Dec7 2023. Did you have to copy that cert from /etc/letsencrypt/live folder or somehow import it to the LiteSpeed admin panel? I am just hoping to trigger a memory for you.
Thanks, no worrries Mike I will find out how to check LiteSpeed configuration.
When I first created the server enviroment at Digital Ocean (Droplet) and selected Wordpress LiteSpeed, SSL certification (Let`s Encrypt) was very simple to generate and the configuration is automatic. I did not copy or import the certicate...
I could manage to access LiteSpeed configuration system (WordPress | Images | Cloud | LiteSpeed Documentation). Https is working again!!!! Thanks for your support.
I am just thinking of deleting compass.com.br-0001 certifications because it seems to be useful...
