Certbot not renewing for correct domain
ottawakaraoke.com
certbot
What would you like to do?
Deploying Certificate to VirtualHost /etc/nginx/conf.d/wordpress_https.conf
nginx: [warn] conflicting server name "ottawakaraoke.com" on 0.0.0.0:443, ignored
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
No matching insecure server blocks listening on port 80 found.
Congratulations! You have successfully enabled https://ottawakaraoke.com
https://www.ssllabs.com/ssltest/analyze.html?d=ottawakaraoke.com
ubuntu 16
nginx
secret company
putty.exe
putty.exe
latest
Hello @ianarman1,
Here we are again :wink:
Seems there is a bit mess on your nginx conf, your domain ottawakaraoke.com is using the cert issued to athena.ottawakaraoke.com and athena.ottawakaraoke.com is using the cert issued to ottawakaraoke.com
Could you please show us the output of these commands?
sudo certbot certificates
sudo nginx -T
Cheers,
sahsanu
Your configuration needs to be working correctly.
certbot won't fix configuration problems.
oh hey! @sahsanu
Attempting to parse the version 1.9.0 renewal configuration file found at /etc/letsencrypt/renewal/athena.ottawakaraoke.com.conf with version 0.31.0 of Certbot. This might not work.
Renewal configuration file /etc/letsencrypt/renewal/athena.ottawakaraoke.com.conf produced an unexpected error: expected /etc/letsencrypt/live/athena.ottawakaraoke.com/cert.pem to be a symlink. Skipping.
Renewal configuration file /etc/letsencrypt/renewal/athena1.ottawakaraoke.com.conf produced an unexpected error: expected /etc/letsencrypt/live/athena1.ottawakaraoke.com/cert.pem to be a symlink. Skipping.
Attempting to parse the version 1.9.0 renewal configuration file found at /etc/letsencrypt/renewal/help.ottawakaraoke.com.conf with version 0.31.0 of Certbot. This might not work.
Renewal configuration file /etc/letsencrypt/renewal/help.ottawakaraoke.com.conf produced an unexpected error: expected /etc/letsencrypt/live/help.ottawakaraoke.com/cert.pem to be a symlink. Skipping.
Attempting to parse the version 1.9.0 renewal configuration file found at /etc/letsencrypt/renewal/ottawakaraoke.com.conf with version 0.31.0 of Certbot. This might not work.
Renewal configuration file /etc/letsencrypt/renewal/ottawakaraoke.com.conf produced an unexpected error: expected /etc/letsencrypt/live/ottawakaraoke.com/cert.pem to be a symlink. Skipping.
Renewal configuration file /etc/letsencrypt/renewal/pallas.ottawakaraoke.com.conf produced an unexpected error: expected /etc/letsencrypt/live/pallas.ottawakaraoke.com/cert.pem to be a symlink. Skipping.
Found the following certs:
 Certificate Name: ottawakaraoke.com-0001
   Domains: ottawakaraoke.com athena.ottawakaraoke.com
   Expiry Date: 2021-03-23 09:58:09+00:00 (VALID: 87 days)
   Certificate Path: /etc/letsencrypt/live/ottawakaraoke.com-0001/fullchain.pem
   Private Key Path: /etc/letsencrypt/live/ottawakaraoke.com-0001/privkey.pem
 Certificate Name: ottawakaraoke.com-0002
   Expiry Date: 2021-03-26 07:15:42+00:00 (VALID: 89 days)
   Certificate Path: /etc/letsencrypt/live/ottawakaraoke.com-0002/fullchain.pem
   Private Key Path: /etc/letsencrypt/live/ottawakaraoke.com-0002/privkey.pem
The following renewal configurations were invalid:
here is my conf file
upstream php-handler-https {
        server 127.0.0.1:9000;
        listen 443 ssl default_server;
        server_name ottawakaraoke.com;
        #server_name wordpress.example.com;
    ssl_certificate /etc/letsencrypt/live/ottawakaraoke.com-0002/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/ottawakaraoke.com-0002/privkey.pem; # managed by Certbot
#Security Policy
add_header Content-Security-Policy "default-src 'none';
    script-src 'self' 'unsafe-inline' 'unsafe-eval'
        https://apis.google.com
        www.google-analytics.com
        *.googlesyndication.com
        *.doubleclick.net
        *.cloudflare.com
        *.bootstrapcdn.com;
    style-src 'self' 'unsafe-inline'
        https://fonts.googleapis.com
        *.bootstrapcdn.com;
    img-src 'self' data:
        www.google.com
        www.google.fr
        *.cloudflare.com
        *.doubleclick.net;
    font-src 'self'
        https://fonts.gstatic.com
        *.bootstrapcdn.com;
        connect-src 'self';
    frame-src 'self' 'unsafe-inline'
        *.doubleclick.net;
    frame-ancestors 'none';
    form-action 'none';
    upgrade-insecure-requests;
    block-all-mixed-content;
    reflected-xss block;
    base-uri 123run.com www.123run.com;
    referrer no-referrer-when-downgrade";
#       root /var/www/html/;
        root /var/www/html/songportal.dev.ottawakaraoke.com/html/;
        index index.html;
        # set max upload size
        client_max_body_size 2G;
        fastcgi_buffers 64 4K;
        access_log /var/log/nginx/wordpress_https_access.log combined;
        error_log /var/log/nginx/wordpress_https_error.log;
Did you happen to delete anything from the letsencrypt folder?
no - although I'm trying to change my domain name from the subdomain to the actual domain.
the subdomain was for dev.
the files still exist.
-rw-r--r-- 1 root root 576 Nov 15 03:32 /etc/letsencrypt/renewal/athena.ottawakaraoke.com.conf
I suppose that is part of the problem.
Again, certbot can't fix your nginx configuration.
You need to review your nginx configuration and get it working as you would like it to be.
Then you can run certbot.
[which should just work - but may still show problems related to those "missing" files.]
the domain in the config is correct and the dns is pointing correctly and Wordpress has the correct domain in the db.
ottawakaraoke.com
it's very strange.
There are some obviously troubling things with this output:
  1. both certs have one (overlapping) name.
  2. both certs end with -000# (which means they were conflicting with yet another presumed now deleted cert.)
The entire config was requested:
Only a small part was shown.
If you can't show the entire config (as requested), maybe you can show this output:
nginx -T | grep -Ei 'listen|root|server_name|cert|encrypt|virt|config|location'
Otherwise it will be quite difficult for anyone here to help you.
    application/x-x509-ca-cert                       der pem crt;
# configuration file /etc/nginx/conf.d/cockpit.conf:
        listen 9080 ssl;
        server_name _;
        ssl_certificate /etc/nginx/ssl/server.crt;
        ssl_certificate_key /etc/nginx/ssl/server.key;
                location ~* \.(htaccess|htpasswd) { #COCKPIT_AUTH
# configuration file /etc/nginx/conf.d/wordpress_http.conf:
#       root /var/www/html/athena/html/;
        location = /favicon.ico {
        location = /robots.txt {
        location ^~ /xhprof/xhprof_html/ {
                location ~ \.php(?:$|/) {
                  fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
        location ^~ /mysqladmin/ {
        location ^~ /wp-admin/ {
        location ~* \.(?:jpg|jpeg|gif|bmp|ico|png|css|js|swf)$ {
    ssl_certificate /etc/letsencrypt/live/athena.ottawakaraoke.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/athena.ottawakaraoke.com/privkey.pem; # managed by Certbot
    } # managed by Certbot
        listen 80 default_server;
        server_name pallas.ottawakaraoke.com;
# configuration file /etc/nginx/fastcgi_params:
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_NAME        $server_name;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# configuration file /etc/nginx/conf.d/wordpress_https.conf:
Both of these files listen on port 443 for the same name:
Judging by the file names, the first should only be listening to HTTP (port 80), but it is listening to 80 and 443.
Each [IP:PORT:FQDN] combination must be unique.
