I ran this command:sudo /tmp/certbot/certbot-auto certonly --webroot -w /opt/tomcat/apache-tomcat/webapps/ROOT/ -d demo.bigopen.eu
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for demo.bigopen.eu
Using the webroot path /opt/tomcat/apache-tomcat/webapps/ROOT for all unmatched domains.
Waiting for verification…
Unable to clean up challenge directory /opt/tomcat/apache-tomcat/webapps/ROOT/.well-known/acme-challenge
Failed authorization procedure. demo.bigopen.eu (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://demo.bigopen.eu/.well-known/acme-challenge/xdHTnN6bNePQY5llSAgnGHI44YDfg8kOnYHkU3N_Dqo: “Apache Tomcat/8.0.38 - Error reportH1 {font-family:Tahoma,Arial”
My web server is (include version): Apache Tomcat/8.0.38
The operating system my web server runs on is (include version):Ubuntu 14.04 LTS
My hosting provider, if applicable, is: Amazon EC2
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The problem seems to get for my browser (and for acme) anything from a “.well-known” subdir (acme-challenge in this case). If I manually put a file in another sibling “well-known” directory(without trailing dot) I can read it from my browser.
The weird thing is that I already succeedeed once, and the correct certs were generated and installed (thru webroot option). Now, at the time of renewing, I got this
strange behavior. The tricky policy of Bitnami Apache does not help.
Should I better ask the Bitnami people?
I already crawled thru this community but I could not find any similar case.
Thank you good willing men
I think that's a good start. You can also share your apache configs here, and check for any ".htaccess" files that might be setting policies to not serve dotfiles.
dear jsha,
thank you for your reply.
I cannot find .htaccess files in the significant part of my file system (looking for -la option of course). Nonethe less I am ignorant about .htaccess usage.
Here is what is supposed to be the main .conf file in Bitnami realm, that is
/opt/tomcat/apache2/conf/bitnami/bitnami.conf:
# Default Virtual Host configuration.
<IfVersion < 2.3 >
NameVirtualHost *:80
NameVirtualHost *:443
</IfVersion>
<VirtualHost _default_:80>
DocumentRoot "/opt/tomcat/apache2/htdocs"
<Directory "/opt/tomcat/apache2/htdocs">
AllowOverride All
<IfVersion < 2.3 >
Order allow,deny
Allow from all
</IfVersion>
<IfVersion >= 2.3 >
Require all granted
</IfVersion>
</Directory>
# Error Documents
ErrorDocument 503 /503.html
# Bitnami applications installed with a prefix URL (default)
Include "/opt/tomcat/apache2/conf/bitnami/bitnami-apps-prefix.conf"
</VirtualHost>
# Default SSL Virtual Host configuration.
<IfModule !ssl_module>
LoadModule ssl_module modules/mod_ssl.so
</IfModule>
Listen 443
SSLProtocol all -SSLv2 -SSLv3
SSLHonorCipherOrder on
SSLCipherSuite "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384 EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS !EDH !RC4"
SSLPassPhraseDialog builtin
SSLSessionCache "shmcb:/opt/tomcat/apache2/logs/ssl_scache(512000)"
SSLSessionCacheTimeout 300
<VirtualHost _default_:443>
SSLEngine on
#SSLCertificateFile "/opt/tomcat/apache2/conf/server.crt"
SSLCertificateFile "/etc/letsencrypt/live/demo.bigopen.eu/fullchain.pem"
SSLCertificateKeyFile "/etc/letsencrypt/live/demo.bigopen.eu/privkey.pem"
#SSLCertificateKeyFile "/opt/tomcat/apache2/conf/server.key"
AllowOverride All
<IfVersion < 2.3 >
Order allow,deny
Allow from all
</IfVersion>
<IfVersion >= 2.3 >
Require all granted
</IfVersion>
</Directory>
# Error Documents
</VirtualHost>
# Bitnami applications that uses virtual host configuration
Include "/opt/tomcat/apache2/conf/bitnami/bitnami-apps-vhosts.conf"
I am aware that the
is NOT the root dir under which I expect the .well-known stuff to be dropped, i.e.
but the latter is what is actually used by bitnami apache. I still can’t understand the way it works, but it works.
It seems like this (and the other includes) might be the key to your problem, along with the difference between /opt/tomcat/apache2/htdocs and /opt/tomcat/apache-tomcat/webapps/ROOT, as you point out.
I'd recommend trying the Apache plugin for certbot: certbot --apache.
Include “/opt/tomcat/apps/phpmyadmin/conf/httpd-prefix.conf”
$ cat /opt/tomcat/apps/phpmyadmin/conf/httpd-prefix.conf
Alias /phpmyadmin/ "/opt/tomcat/apps/phpmyadmin/htdocs/"
Alias /phpmyadmin “/opt/tomcat/apps/phpmyadmin/htdocs”
Include “/opt/tomcat/apps/phpmyadmin/conf/httpd-app.conf”
first of all, I want to thank jmorahan and jsha for their precious support and help.
I overcame the problem observing in Tomcat Manager, a console I normally do not use, that the links to applications and services are originated under
and not under
So, I relaunched the certbot-auto with the --webroot option pointing to the correct root and it worked. (it just couldn’t flush the acme-challenge directory, but it wrote into it anyway)
Still don’t know the trick Bitnami uses to bounce the document root away, I will further investigate.
