I'm using a control panel to manage my site (no): see below for more details
My certificates are due to expire 3/10/2020. I've received email notification to that effect.
Operating System is Linux Opensuse Leap 15.1, Web Server is Apache, e-commerce software is Oscommerce phoenix, certbot version 1.4.0, DNS reg with Godaddy.
I have reinstalled the certs a few times in the past with
"sudo certbot -1 apache -w /srv/www/htdocs -d www.smoothgift.com -d smoothgift.com" without error.
A couple of weeks ago, I changed IP address and had to reinstall Oscommerce Phoenix.
Site DNS is good. But I forgot about Letsencrypt's .well known directory and deleted it along with the old Oscommerce Phoenix files (I think ).
I also cannot remember the password I used in setting up the certbot certifcates.
And if I'd used "sudo certbot" certbot will reply like: Certs not due for renewal. No renewal was attempted. But the certs will expire 3/10/2020.
What I would like is to be able to reinstall certificates and use a new password in the process.
Is this possible? Or may be wait for 3/10/2020 (certs expiration) and then issue new ones?
Other than these, what can I do to resolve this problem please?
Thanks or your response.
The .well-known directory does not exist, was deleted. Isn't that why fetching it timed out?
Http port 80 is open which is why it could be redirected to https:443 or not? Do you mean that I have to stop redirect first to validate?
Beats me! Well, I have now taken it off permanent redirect. Please let me know if site is still not loadable.
So permanent redirect is a good practice, I read and moreso, I need to have site redirected permanently to https for obvious reasons. Now that I have both http and https available, does that mean that I will always have to leave http and https available in order for certbot to be able to renew/reissue/reinstall certificates? Do I understand that correctly? Please advise.
I have looked into these but found non of them to be the case. Is there something else I could look into to help clarify these assumptions please?
Could you please explain why this is irrelevant?
Like I explained, my reason for wanting a new certificate is to be able to have a password that can be used when exporting/deploting letsencrypt certificate to be used elsewhere other than the webroot-path. I cannot do this at the moment. What's the way out?
I tried quite a few different tools, but without success. Are you able to access your site from a mobile device? It looks like you were able to successfully get certificates a few months ago (https://crt.sh/?q=smoothgift.com). In changing your IP address did you also change hosting providers?
To clarify, you need ports 80 (http) and 443 (https) open and operating in order for the addresses above to function. You can (and should) have a redirect from http to https (and from non-www to www or vice versa). That applies to having your website function correctly, not just for getting a certificate from Let's Encrypt.
To which password do you refer? The private encryption key for the certificate perhaps?
For your certbot command, I think you may have some typos. I have cleaned it up and enhanced it based on what I believe you want: sudo certbot run --cert-name smoothgift.com -a webroot -w /srv/www/htdocs -d smoothgift.com,www.smoothgift.com -i apache
Edit:
You could always use dns-01 challenges instead of the http-01 challenges you've been using since your DNS records are publicly visible. It would start out as a manual process, but it could probably be automated later with something like acme-dns. Here's the command, which will require you to manually create two TXT records in your DNS: sudo certbot run --cert-name smoothgift.com -a manual --preferred-challenges dns -d smoothgift.com,www.smoothgift.com -i apache
Totally my bad to have assumed that site was loadable externally without checking it outside of it's internal IP range. Related telnet, netstat etc commands were telling me that ports were open and I did not hang around long enough to see that connections were interrupted and closed like 20 secs afterwards by foreign host. Culprit was of course my modem port forwarding. Sorted out now. Ports are open.
griffin, I cannot thank you enough!
Also, I appreciate your efforts in clarifying things for me and pointing me in the right direction.
Using the dns-01 challenges would have been the better way to go now except I would need to read up first on acme-dns to know how to automate renewal (unless you have a lead for me there). So I will stick to the http-01 challenges (compliments of cronjob for renewal) but do not know how to go about the password issue. This still leaves me unable to answer your questions "To which password do you refer? The private encryption key for the certificate perhaps?" I am talking about the password you have to give ONLY the FIRST time you requested Certbot for certificates & key. For example, if I would like to use certificates issued by Certbot for Pentaho server, it would need to be implemented via openssl keystore. The keystore of course will request for the password used in creating the Certbot certficate. Hope you understand the 'password' I'm going on about now. I have forgotten the password so I need brand new certificates. If I request for a new certificate now Certbot will just give me one but will not ask me for a password input which I need.
I guess I could put back the http to https redirect as it would not be in the way of Certbot reissue/renewal.
My apologies Juergen. The ports are open but my modem port forwarding was not working, so technically, you were correct. Site is loadable now I believe.
Good: All checks /.well-known/acme-challenge/random-filename without redirects answer with the expected http status 404 - Not Found. Creating a Letsencrypt certificate via http-01 challenge should work. If it doesn't work: Check your vHost configuration (apachectl -S, httpd -S, nginx -T). Every combination of port and ServerName / ServerAlias (Apache) or Server (Nginx) must be unique. Merge duplicated entries in one vHost. If you use an IIS, extensionless files must be allowed in the /.well-known/acme-challenge subdirectory. Create a web.config in that directory. Content: <system.webServer></system.webServer>. If you have a redirect http ā https, that's ok, Letsencrypt follows such redirects to port 80 / 443 (same or other server). There must be a certificate. But the certificate may be expired, self signed or with a not matching domain name. Checking the validation file Letsencrypt ignores such certificate errors.
The next step would be for you to try to generate a new certificate. As for the lost openssl keystore password issue, I'm not really sure. I'll do some research and get back to you there.
I have been able to use both http-01 challenges and dns-01 challenges using the commands given by griffin. Both worked. Certs are now valid till 24/12. I used both option 1 (reinstall) and option 2 (renew) for both commands. That's great! BUT BOTH still did not give me the option to input password which really defeats my original purpose. It makes Letsencrypt issued certs not usable for other applications (using openssl keystore) like Pentaho server, ofbiz server, etc
In case of the dns-01(sudo certbot run --cert-name smoothgift.com -a manual --preferred-challenges dns -d smoothgift.com,www.smoothgift.com -i apache) I did not get a chance to manually create two TXT records in your DNS contrary to expectation but certs were issued though.
Is it safe to conclude now that Letsencrypt's certbot don't do proper reissue or renew (with challenges and password)? Please advise.
That's completely wrong. These applications may need other formats, may be pfx. So use OpenSsl to create the required pfx file. Then you can add a password.
You are mixing things that are completely separated.
Getting somewhere Been able to get certs issued using both of your commands. pls read more about it above @ [JuergenAuer]. Still stuck with the password issue. Don't know what to do as it is. Will hold on though to see if you could come up with a solution. Grateful!
Ok. I will go and look into your suggestion. My experience so far is that I would need a password for the keystore itself (like you said) but it wants the password used @ certbot as well to be able to copy certs to keystore which makes sense for security sake. Came across another way to use it directly (without keystore) but the password is also required.
"That's not required if you have an Apache." But I am using apache.
If you don't mind my asking, Rich, can you please describe your password scenario specifically so we can address it in one place. It's not too common around here, so we want to make sure we understand clearly.
