sudo mv certbot-auto /etc/letsencrypt/
mv: cannot move ‘certbot-auto’ to ‘/etc/letsencrypt/’: Not a directory
Google Cloud Platform
Distributor ID: Debian
Description: Debian GNU/Linux 9.11 (stretch)
Release: 9.11
Codename: stretch
Yes
No
-bash: certbot-auto: command not found
-bash: certbot: command not found
I thought I was using certbot, at least I though I just downloaded it again, but it still gives me this output.
I already have a ssl certificate from Let’s Encrypt, but need to renew. I tried it the last time and failed miserably forcing me to move my domain and start all over. This snowballed in my client not having email and invoicingsystems working. The situation now is that I have to renew before the 12th of March, but cant manage to do so. Already at the first couple of steps for renewing I am encountering problems of it not finding the right directory. Leaving me clueless on how to continue.
If that directory is not empty it's plausible you did indeed use certbot and apt somehow made it disappear, probably unmet dependencies or something. It should be safe to just install it again.
I used that command because I am following the steps from this link:
I think I just reinstalled the certbot, because when I give the command ‘certbot-auto --version’ it gives me this output:
Requesting to rerun /usr/local/bin/certbot-auto with root privileges…
certbot 1.3.0.
But I still dont know now how to renew. I added this command ’ 1. echo “0 0,12 * * * root python -c ‘import random; import time; time.sleep(random.random() * 3600)’ && /usr/local/bin/certbot-auto renew -q” | sudo tee -a /etc/crontab > /dev/null’ But it seems as if that didnt do the trick, since the expire date is still on the 12th.
I feel dumb. I used the debian (other). But, now i did use the right one and followed the steps.
The command ‘certbot renew’ now gives me the following output:
The following error was encountered:
[Errno 13] Permission denied: ‘/var/log/letsencrypt/.certbot.lock’
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): crisisprofs.com
http-01 challenge for crisisprofs.com
Enabled Apache rewrite module
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ’
ServerName’ directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
I guess because I was convinced it was apache… Didnt set it up myself so not 100% sure, got given this problem and obviously not an expert. Do you know how I can retrace this and figure out what the webserver is? My apologies for the obvious questions…
