My domain is:walkershire.net
My web server is (include version): Apple Mini
MACOS Monerey 12.6
My hosting provider, if applicable, is:my company server on Comcast Business
or certbot-auto --version
if you're using Certbot):1.30.0
I have several domains with LetsEncript certificates which were installed about July 10, 2022. I tried to renew them on September 20 but had the --apache-bin is missing error and the PluginError('Unable to create a lock file in /etc/apache2.”. I found a fix by Griffin on Community.LetsEncript and tried it. The response said the it was successful with a mid December expiration date. I later checked the certificates expiration by clicking on the lock icon using a browser which showed Saturday, October 8, 2022 at 2:22:19 PM.
Today I reinstalled Apache and then CertBot version 1.30.0 using Brew. Then ran certbot renew and got the same apache-bin and PluginError as before.
Ran Griffins ‘ certbot certonly --webroot -w /path/to/webroot/for/www.sobco.com -d "www.sobco.com" --dry-run ‘. Log shows:
The dry run was successful.
lowerlevel@70-89-220-117-clean-air-engineering-il ~ % certbot certonly --webroot -w /usr/local/var/www/walkershire -d "www.walkershire.net"
Saving debug log to /usr/local/etc/certbot/logs/letsencrypt.log
(ref: /usr/local/etc/certbot/certs/renewal/www.walkershire.net.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for www.walkershire.net
Certificate is saved at: /usr/local/etc/certbot/certs/live/www.walkershire.net/fullchain.pem
Key is saved at: /usr/local/etc/certbot/certs/live/www.walkershire.net/privkey.pem
This certificate expires on 2022-12-31.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See User Guide — Certbot 1.30.0 documentation for instructions.
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
But the browser locks shows October 8, 2022 at 2:22:19 PM because they are not using the www certificate folder.
There are 2 folders in usr/local/etc/certbot/certs/live. Walkershire.net and www.walkershire.net. That may be because I
1st created 5 certificates for the plain domain names:
2022-07-18 17:31:36,150:DEBUG:certbot._internal.display.obj:Notifying user: Found the following certs:
Certificate Name: walkershire.net
Domains: walkershire.net beyond.cleanair.com d7036.com envirotemps.com hi-tech.rent
Later with late night help from rg305(who is very good) on my CaptainBill log Challenges Failed Due To Invalid Response From .well-known I created the 11 domain certificates as can be seen at the bottom of this thread.
What should I do to get all 11 certificates renewed ?
