Inexplicable certbot-auto renew error
Good day.
I have a certificate (example.com) which expired a couple days ago. I’m trying to renew it with ./letsencrypt/certbot-auto renew but I’m getting errors regarding not getting access to my /.well-known directory, which is present and should be accessible.
This is the complete output when I use the command:
Processing /etc/letsencrypt/renewal/example.com.conf
http-01 challenge for example.com
Attempting to renew cert (example.com) from /etc/letsencrypt/renewal/example.com.conf produced an unexpected error: Failed authorization procedure. example.comu (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://example.com/.well-known/acme-challenge/06TXVpJMgS_JL_8E5RhYLXAjesHdZL_fR8uKRnPplvQ: "<html>
<head><title>404 Not Found</title></head>
<body bgcolor="white">
<center><h1>404 Not Found</h1></center>
<hr><center>". Skipping.
  /etc/letsencrypt/live/example.com/fullchain.pem (failure)
   Domain: example.com
   Type:   unauthorized
   Detail: Invalid response from
   "<html>
   <hr><center>"
I’ve checked and it really pass through my DNS properly, then it goes through a Squid reverse proxy which ends in a 404 error:
z1511792411.640 4 13.58.30.69 TCP_MISS/404 367 GET http://example.com/.well-known/acme-challenge/06TXVpJMgS_JL_8E5RhYLXAjesHdZL_fR8uKRnPplvQ - HIER_DIRECT/192.168.20.11 text/html
Also I have /.well-known properly declared in website’s .conf:
location ^~ /.well-known/ {
allow all;
default_type "text/plain";
What could be happening there?
My webserver is Nginx 1.10.3, and my OS is Ubuntu 16.04.3 LTS.
Thanks in advance.
Warm regards.
What it the root of that domain in the nginx configuration?
This seems to be a filesystem mapping issue.
