Using Munin with Let's Encrypt (certificate verify failed) #420
Hey,
I tried to use Munin with Let's Encrypt but I run into the following issue:
SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
I googled a bit and found something about MySQL, config setting seems to be similar:
Still returns me the same error.
My SSL settings for munin which are placed into munin.conf and munin-node.conf are the following:
tls paranoid
tls_verify_certificate yes
tls_private_key /etc/munin/keys/privkey.pem
tls_certificate /etc/munin/keys/cert.pem
tls_ca_certificate /etc/munin/keys/chain.pem
tls_verify_depth 5
Certificate Files I used from Let's Encrypt, according to the Post above:
/etc/letsencrypt/live/DOMAIN.pw/privkey.pem
/etc/letsencrypt/live/DOMAIN.pw/cert.pem
/etc/letsencrypt/live/DOMAIN.pw/chain.pem
And It still returns the certificate validation error.
Anyone got an idea?
Hi @Neoon,
You could find out what Munin is sending back to TLS clients with
openssl s_client -connect host:port -servername host
where host is the hostname and port is the port number.
