Using Let's Encrypt certs with MySQL for database replication
Hello,
I’m trying to set up a database replication so that it uses secure connections, but it is not clear what certificates I have to use. Here is my current configuration:
[mysqld]
# ssl-ca identifies the Certificate Authority (CA) certificate.
# wget https://letsencrypt.org/certs/lets-encrypt-x3-cross-signed.pem
ssl-ca=/etc/ssl/certs/lets-encrypt-x3-cross-signed.pem
# ssl-cert identifies the server public key certificate. This can be sent to the client and authenticated against the CA certificate that it has.
ssl-cert=/etc/letsencrypt/live/MYDOMAIN/cert.pem #  or chain.pem|fullchain.pem ?
# ssl-key identifies the server private key.
ssl-key=/etc/letsencrypt/live/MYDOMAIN/privkey.pem
My doubts are on the first two options. Are they correct?
Thanks.
2nd is correct, 1st is wrong. Change that one to chain.pem, that way it’ll still work if the intermediate is changed.
